NetApp Knowledge Base
ClusterSwitchConfig_Alert reported in system health alert for non-existing switch
778
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • Cluster Switch Health Monitor (CSHM) AutoSupport message
Issue
  • Subsystem health for switch gets degraded:
cluster1::> system health subsystem show
Subsystem         Health
SAS-connect       ok
Environment       ok
Memory            ok
Service-Processor ok
Switch-Health     degraded
CIFS-NDO          ok
Motherboard       ok
IO                ok
MetroCluster      ok
MetroCluster_Node ok
FHM-Switch        ok
FHM-Bridge        ok
SAS-connect_Cluster ok
  • system health alert show example:
               Node: node_name1
           Resource: node_name2
           Severity: Major
    Indication Time: Fri Aug 13 23:03:53 2021
           Suppress: false
        Acknowledge: false
     Probable Cause: One or more nodes are not connected to both cluster
                     switches.
    Possible Effect: If one cluster switch fails, "node_name2" might lose
                     access to the cluster.
 Corrective Actions: Ensure the switch "no_switch_name1" is connected
                     to the node "node_name2".
               Node: node_name1
           Resource: no_switch_name1
           Severity: Major
    Indication Time: Fri Aug 13 23:29:53 2021
           Suppress: false
        Acknowledge: false
     Probable Cause: Cluster switch "no_switch_name1" with IP address
                     "123.123.123.123" is not reachable via SNMP. Incorrect
                     SNMP community string might be configured on the
                     cluster switch.
    Possible Effect: Cluster switch communication problems and
                     accessibility issues.
 Corrective Actions: Check the SNMP community string on the cluster switch
                     to verify the expected community string is configured.
                     Use the "system cluster-switch show -snmp-config"
                     command to view the expected community string.
  • The switch name and IP address in the alert do not belong to any cluster switches or is reported in the case of a switchless cluster.
  • EMS log example:
Fri Aug 13 23:05:50 +0100 [node_name1: mgwd: callhome.hm.alert.major:alert]: Call home for Health Monitor process cshm: ClusterSwitchConfig_Alert[node_name2].
Fri Aug 13 23:30:51 +0100 [node_name1: mgwd: callhome.hm.alert.major:alert]: Call home for Health Monitor process cshm: SwitchCommunityString_Alert[no_switch_name1].
Fri Aug 13 23:03:54 +0100 [node_name1: cshmd: hm.alert.raised:alert]: Alert Id = ClusterSwitchConfig_Alert , Alerting Resource = node_name2 raised by monitor cluster-switch
Fri Aug 13 23:29:53 +0100 [node_name1: cshmd: hm.alert.raised:alert]: Alert Id = SwitchCommunityString_Alert , Alerting Resource = no_switch_name1 raised by monitor cluster-switch
Fri Aug 13 23:29:53 +0100 [node_name1: cshmd: hm.alert.raised:alert]: Alert Id = SwitchCommunityString_Alert , Alerting Resource = no_switch_name2 raised by monitor cluster-switch
  • network port show -node * -role cluster -fields remote-device-id reports the correct cluster network switches.
New to NetApp?
