NetApp Knowledge Base
Service port configuration conflicts with the configured IP Address in CN1610 switch
157
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
Applies to
CN1610 cluster switches
Issue
  • Ping/SSH does not work on CN1610 cluster switch, as the service port is not properly configured with an IP address:
(Switch)#show serviceport
Interface Status............................... Up
IP Address..................................... 0.0.0.0
Subnet Mask.................................... 0.0.0.0
Default Gateway................................ 0.0.0.0
IPv6 Administrative Mode....................... Enabled
IPv6 Prefix is ................................ fe80::2a0:94ff:feef:560e/64
Configured IPv4 Protocol....................... None
Configured IPv6 Protocol....................... None
IPv6 AutoConfig Mode........................... Disabled
Burned In MAC Address.......................... 00:A0:96:EF:56:0E
  • Service port configuration conflicts with the configured IP address in the switch.
(Switch)#serviceport ip 172.70.10.10 255.255.255.0 172.70.10.1
IP Address/Netmask entered conflicts with the configured IP Address/Netmask of
the switch.
  • It can be found that the same IP address is assigned to the network port.
(Switch)#show network
IP Address..................................... 172.70.10.10
Subnet Mask.................................... 255.255.255.0
Default Gateway................................ 172.70.10.1
Burned In MAC Address.......................... 00:A0:98:EF:58:0D
Locally Administered MAC address............... 00:00:00:00:00:00
MAC Address Type............................... Burned In
Management VLAN ID............................. 1
New to NetApp?
Scan to view the article on your device
