NetApp Knowledge Base
Port a0a is reporting a high number of observed hardware errors
296
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
ONTAP 9
Issue
  • EMS error
[netapp--8300-02: vifmgr: vifmgr.cluscheck.hwerrors:alert]: Port a0a on node netapp--8300-02 is reporting a high number (at least 1 per 1000 packets) of observed hardware errors (CRC, length, alignment, dropped).
[netapp--8300-02: vifmgr: vifmgr.cluscheck.hwerrors:alert]: Port a0a-2xx on node netapp--8300-02 is reporting a high number (at least 1 per 1000 packets) of observed hardware errors (CRC, length, alignment, dropped).
  • IFSTST-A on transmit shows errors on ifgropu a0a :
-- interface  a0a  (93 days, 9 hours, 33 minutes, 10 seconds) --
TRANSMIT
Totalframes:    43324m | Frames/second:    5369 | Total bytes:     44991g
Bytes/second:    5575k |Total errors:    2465|Errors/minute:       0
Totaldiscards:      0  | Queue overflow:     0  | Multi/broadcast:  2971k
Collisions:         0  | Max collisions:      0  | Singlecollision:    0
Multicollisions:    0  | Latecollisions:     0  |Xon:                0
Xoff:               0  |Pause:              0  | Jumbo:              0
CfgUp to Downs:     0  | TSO non-TCPdrop:    0  | Split hdr drop:     0
Timeout:            0  | TSO segments:     3997m | TSObytes:       40694g
TSO6segments:       0  | TSO6bytes:          0  | HW UDPcksums:       0
HWUDP6 cksums:      0  | HW TCP cksums:  17889m | HW TCP6 cksums:      0
Mcastv6 solicit:    0  |Lagg drops:       2448| Lagg no buffer:      0
Laggno entries:     0
New to NetApp?
Scan to view the article on your device
