NetApp Knowledge Base
Node unreachable due to cluster ports being down
174
Visibility:
Votes:
1
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
Applies to
  • FAS2720
  • ONTAP 9.7P7
  • BES-53248 cluster network switches
Issue
  • Node is seen via storage failover show command
Cluster::> storage failover show
                              Takeover
Node           Partner        Possible State Description
node-01        node-02 true   Connected to node-02
node-02        node-01 true   Connected to node-01
node-03        node-04 true   Connected to node-04
node-04        node-03 true   Connected to node-03
  • Node appears unreachable via node show command
Cluster::> node show
Node Health Eligibility Uptime Model Owner Location
node-01 true true 128 days 00:59 AFF-A220 London
node-02 true true 128 days 00:59 AFF-A220 London
node-03 true true 128 days 00:21 FAS2720 London
node-04 true true - - - -
4 entries were displayed.
  • Based on uptime the node is running
Cluster::> node run -node * -c "uptime"
4 entries were acted on.
Node: node-01  2:32pm up 131 days,  2:30 14786852056 NFS ops, 3892 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops, 0 NVMF ops
Node: node-02  2:32pm up 131 days,  2:30 20465055899 NFS ops, 3884 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops, 0 NVMF ops
Node: node-03  2:32pm up 131 days,  1:52 981629257 NFS ops, 5809919861 CIFS ops, 0 HTTP ops, 0 FCP ops, 3209009366 iSCSI ops, 0 NVMF ops
Node: node-04  2:32pm up 131 days,  1:52 7395009429 NFS ops, 4593427421 CIFS ops, 0 HTTP ops, 0 FCP ops, 0 iSCSI ops, 0 NVMF ops
  • Cluster network ports are reported as down
	slot 0: 10 Gigabit Ethernet Controller IX5-SFP+
		e0a MAC Address:    XX:XX:XX:XX:XX:XX (auto-unknown-fd-down)
		    SFP Vendor:         Molex Inc.
		    SFP Part Number:    747529720
		    SFP Serial Number:  XXXXXXXXX
  • Cluster network switch connected to these ports is reported as missing
Node node-02
Monitor cluster-switch
Alert ID ClusterSwitchMissing_Alert
Alerting Resource switch-01
Subsystem Switch-Health
Indication Time Sat Jun 26 13:42:57 2021
Perceived Severity Major
Probable Cause Configuration_error
Description Redundant configuration is missing for cluster switches.
  • Visual inspection of the switch shows no LED activity on any of the cluster ports
  • When connecting to the switch over serial all cluster ports are shown as having been disabled
(switch-01) #show port all
                 Admin     Physical   Physical   Link   Link    LACP   Actor
Intf      Type   Mode      Mode       Status     Status Trap    Mode   Timeout
0/1              Disable   10G Full              Down   Enable  Enable long
0/2              Disable   10G Full              Down   Enable  Enable long
0/3              Disable   10G Full              Down   Enable  Enable long
0/4              Disable   10G Full              Down   Enable  Enable long
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
