NetApp Knowledge Base
MetroCluster fails to add Brocade switch for monitoring
105
Visibility:
Votes:
0
Category:
metrocluster
Specialty:
brocade
Last Updated:
Applies to
  • MetroCluster
  • Brocade
Issue
MetroCluster fails to add Brocade switch for monitoring by the command storage switch add :
Example:
::> storage switch add 10.64.xx.xx
Error: command failed: Internal error. Failed to add switch for monitoring on node "node_name" in cluster "cluster_name". Reason: Failed to check if device located at "10.64.xx.xx" is from
supported vendor. For further assistance, contact technical support.
New to NetApp?
Scan to view the article on your device
