Issues while trying to upload image in SAN switches "Failed to access sftp"
Applies to
- Brocade6510
Issue
- Getting below error while downloading FOS to Switch:
MCC_Switch_A:admin>firmwaredownload -x 9600 -p sftp 17x.3x.5x.3x,admin,/v8.2.3a_G5_ENTRY/release.plist,hpebna2019
Server IP: 172.30.56.31,
Protocol IPv4
Checking system settings for firmwaredownload...
Failed to access sftp://admin:**********@17x.3x.5x.3x.../release.plist
The server is inaccessible or firmware path is invalid. Please make sure the server name/IP address and the firmware path are valid, the protocol and authentication are supported. It is also possible that the RSA host key could have been changed and please contact the System Administrator for adding the correct hostkey.
