Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
How to check which NetApp FC ports connect to which switch ports
1,494
Visibility:
Votes:
1
Category:
fabric-interconnect-and-management-switches
Specialty:
san
Last Updated:
Applies to
  • NetApp FAS/AFF systems
  • Clustered ONTAP (all versions)
How to check which Fibre Channel (FC) ports on a NetApp node connect to which ports on the FC switch
New to NetApp?
Scan to view the article on your device
