NetApp Knowledge Base
FastPath firmware transfer to the CN1610 cluster switches fails
214
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
  • CN1610
  • FastPath 1.3.03
Issue
Copying the FastPath image file to the cluster network switches fails with "File transfer failed!"
Mode........................................... SFTP
Set Server IP.................................. 10.62.42.163
Path........................................... /opt/app/ess/data/netapp/
Filename....................................... CN1610_1.3.0.3.stk
Data Type...................................... Code
Destination Filename........................... active
Management access will be blocked for the duration of the transfer
Are you sure you want to start? (y/n) y
New to NetApp?
