NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
NetApp Knowledge Base
Error! in configuration script file at line number XX when applying a new RCF
1,897
Visibility:
Votes:
2
Category:
fabric-interconnect-and-management-switches
Specialty:
nas
Last Updated:
Applies to
Cluster switch Broadcom BES-53248
Issue
Error applying a new RCF file to a Broadcom BES-53248. Example:
(CS1) #script apply BES-53248_RCF_v1.6-Cluster-HA.scr
 Are you sure you want to apply the configuration script? (y/n) y
 config
 match cos 5
 Unrecognized command : match cos 5
 Error! in configuration script file at line number 40.
 CLI Command :: match cos 5.
 Aborting script.
 Execution of configuration script 'BES-53248_RCF_v1.6-Cluster-HA.scr' could not be completed.
 WARNING:
 The running configuration may not be the desired configuration. You might want to reload the saved configuration.
New to NetApp?
Scan to view the article on your device
