NetApp Knowledge Base
Cluster interconnect reachability issues following initialization of Cisco Nexus 3132Q-V switch
206
Visibility:
Votes:
2
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
Cisco Nexus 3132Q-V
Issue
After an inital install or replacement of a Cisco Nexus 3132Q-V switch, layer 2 reachability fails between ports that must traverse between both switches.
cluster1::> set -privilege advanced
Warning: These advanced commands are potentially dangerous; use them only when
         directed to do so by NetApp personnel.
Do you want to continue? {y|n}: y
cluster1::*> cluster ping-cluster -node cluster1-01
Host is cluster1-01
Getting addresses from network interface table...
Ping status:
Basic connectivity succeeds on 2 path(s)
Basic connectivity fails on 2 path(s)
cluster1::> network port reachability show -expected-broadcast-domain Cluster:Cluster
Node      Port     Expected Reachability                Reachability Status
cluster1-01
          e0e      Cluster:Cluster                      ok
          e0f      Cluster:Cluster                      no-reachability
New to NetApp?
