NetApp Knowledge Base
Cisco cluster switch missing from device-discovery due to CDP issues
39
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • Cisco Cluster Switches
  • ONTAP 9
Issue
  • One cluster switch is missing from the system and the following alert is reported in the event logs:
[Node-1: mgwd: callhome.hm.alert.major:alert]: Call home for Health Monitor process cshm: ClusterSwitchMissing_Alert[clustersw-01].
  • The switch health is degraded:
::> system health subsystem show
Subsystem         Health
SAS-connect       ok
Environment       ok
Memory            ok
Service-Processor ok
Switch-Health     degraded
CIFS-NDO          ok
Motherboard       ok
IO                ok
MetroCluster      ok
MetroCluster_Node ok
FHM-Switch        ok
FHM-Bridge        ok
SAS-connect_Cluster ok
  • All the cluster ports connected to the cluster switch are online, but missing in device-discovery show output.
  • Even after adding the cluster switch to health monitoring, the switch is not reported in the device-discovery show output.
  • From the switch logs, the NetApp nodes connected to the switch are not reported under show cdp neighbors output.
  • CDP is enabled on both the node end and switch end, but the cluster switch is still not discovered.
New to NetApp?
Scan to view the article on your device
  • Was this article helpful?
