NetApp Knowledge Base
Chassis Warning C4-1006 and Critical C4-1010 Message reported on Brocade switch
393
Visibility:
Votes:
2
Category:
fabric-interconnect-and-management-switches
Specialty:
brocade
Last Updated:
Applies to
  • Brocade DCX
  • X6 directors
Issue
  • One of the port blade on the switch went to disabled state with below errors reported under errdump :
2020/01/22-19:07:06, [C4-1010], 433, SLOT 2 | CHASSIS, CRITICAL, DCX, S12,C0: Above normal hardware errors were observed: fault1:0x1, fault2:0x64 thresh2:0xb0000064.
2020/01/22-19:20:41, [C4-1006], 434, SLOT 2 | CHASSIS, WARNING, DCX, S12,C0: Various non-critical hardware errors were observed: fault1:0xa, fault2:0x64 thresh1:0xa000000a.
  • In the example above blade on slot 12(S12) is impacted.
slotshow -m:
Slot   Blade Type     ID    Model Name     Status
  1     CP BLADE    175     CPX6           ENABLED
  2     CP BLADE    175     CPX6           ENABLED
  3     SW BLADE    178     FC32-48        ENABLED
  4     SW BLADE    178     FC32-48        ENABLED
  5     SW BLADE    178     FC32-48        ENABLED
  6     SW BLADE    178     FC32-48        ENABLED
  7     CORE BLADE  177     CR32-8         ENABLED
  8     CORE BLADE  177     CR32-8         ENABLED
  9     SW BLADE    178     FC32-48        ENABLED
 10     SW BLADE    178     FC32-48        ENABLED
 11     SW BLADE    178     FC32-48        ENABLED
 12     SW BLADE    178     FC32-48        ENABLED
New to NetApp?
Scan to view the article on your device
