NetApp Knowledge Base
CN1610 cluster interconnect switch shuts down due to high temperature
247
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
Applies to
  • CN1610 cluster switch
  • ONTAP 9
Issue
  • The CN1610 cluster switch shuts down.
  • Switch logs indicate shut down due to power loss:
Power supply state change alarm: Power Supply Unit: 1  ID: 1  Event: 5 - Power Loss
SW1-1 BSP[envMonTask]: cpu_boxs.c(1487) 719 %% Warning temperature reading : 60 deg C!
SW1-1 BSP[envMonTask]: cpu_boxs.c(1512) 726 %% Critical temperature reading : 61 deg C!
SW1-1 BSP[envMonTask]: cpu_boxs.c(2050) 727 %% Starting 2 minute shutdown timer !
SW1-1 BSP[envMonTask]: cpu_boxs.c(2095) 728 %% System shutting down !
  • If this issue happens on both cluster switches, then the cluster rings can be seen going offline which can further cause:
    • Nodes generating NODE(S) OUT OF CLUSTER QUORUM) EMERGENCY  autosupport.
    • Aggregates, volumes, LIFs etc may be listed as offline in the show outputs using CLI.
    • Nodes may not get listed properly (even if they are online).
cluster1::> node show
Node      Health Eligibility Uptime        Model       Owner
node-1    false  true                    - -           -
node-2    false  true        71 days 19:42 FAS8060
node-3    false  true                    - -           -
node-4    false  true                    - -           -
4 entries were displayed.
New to NetApp?
