Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
CN1610 "show tech-support" command shows temperature sensor warning
366
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
Applies to
CN1610
Issue
Temperature sensor warning in show environment section of show tech-support command:
[Mon Feb 01 12:24:40.974 2021] *************** show environment ***************
[Mon Feb 01 12:24:40.974 2021] Temp (C)....................................... 40
[Mon Feb 01 12:24:40.974 2021] Fan Speed, RPM................................. 9300
[Mon Feb 01 12:24:40.974 2021] Fan Duty Level................................. 75%
[Mon Feb 01 12:24:40.974 2021] Temperature traps range: 0 to 60 degrees (Celsius)
[Mon Feb 01 12:24:40.974 2021] Temperature Sensors:
[Mon Feb 01 12:24:40.974 2021] Unit     Sensor  Description       Temp (C)    State           Max_Temp (C)
[Mon Feb 01 12:24:40.974 2021] ----     ------  ----------------  ----------  --------------  --------------
[Mon Feb 01 12:24:40.974 2021] 1        1       CPU & SWITCH      40          Normal          48
[Mon Feb 01 12:24:40.974 2021] 1        2       Left PHY's        40          Normal          42
[Mon Feb 01 12:24:40.974 2021] 1        3       Right PHY's       0           Warning         46
New to NetApp?
Scan to view the article on your device
