Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
Brocade switch reporting high temperature and "overheating"
540
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
brocade
Last Updated:
Applies to
Brocade G620
Issue
One of the temperature sensors reports a high value
  • Verified sensor status
/fabos/cliexec/sensorshow:
sensor  1: (Temperature) is Ok, value is 39 C
sensor  2: (Temperature) is Ok, value is 48 C
sensor  3: (Temperature) is Ok, value is 44 C
sensor  4: (Temperature) is Ok, value is 42 C
sensor  5: (Temperature) is Ok, value is 42 C
sensor  6: (Temperature) is Ok, value is 37 C
sensor  7: (Temperature) is Ok, value is 63 C
sensor  8: (Fan        ) is Ok,speed is 8141 RPM
sensor  9: (Fan        ) is Ok,speed is 8239 RPM
sensor 10: (Power Supply) is Faulty
sensor 11: (Power Supply) is Ok
  • The average temperature value of all the active sensors (in the above example all 7) should be averaged out
New to NetApp?
Scan to view the article on your device
