NetApp Knowledge Base
Brocade Switch 5100 fan failure
569
Visibility:
Votes:
0
Category:
metrocluster
Specialty:
metrocluster
Last Updated:
Applies to
  • Brocade Switch 5100 BSWITCH-24P-MC-R5-C
  • KERNEL: 2.6.14.2 FABRIC
  • V6.1.1A
Issue
Brocade switch (5100) reports failed fans, however, the healthy power supply sensor reports the following output:
sensor 1: (Temperature ) is Ok, value is 23 C
sensor 2: (Temperature ) is Ok, value is 9 C
sensor 3: (Temperature ) is Ok, value is 17 C
sensor 4: (Temperature ) is Ok, value is 11 C
sensor 5: (Fan ) is Faulty
sensor 6: (Fan ) is Faulty
sensor 7: (Power Supply) is Ok
sensor 8: (Power Supply) is Ok psshow: Power Supply #1 is OK Power Supply #2 is OK fanshow: Fan 1 is Faulty Fan 2 is Faulty
New to NetApp?
Scan to view the article on your device
