NetApp Knowledge Base
Brocade: Messages Warning - C4-1006 and Critical C4-1010
328
Visibility:
Votes:
2
Category:
fabric-interconnect-and-management-switches
Specialty:
brocade
Last Updated:
Applies to
  • Brocade DCX
  • X6 directors
Issue
The customer observes a lot of error on Brocade DCX/X6 directors without any impact:
2020/01/22-19:07:06, [C4-1010], 433, SLOT 2 | CHASSIS, CRITICAL, DCX, S12,C0: Above normal hardware errors were observed: fault1:0x1, fault2:0x64 thresh2:0xb0000064.
2020/01/22-19:20:41, [C4-1006], 434, SLOT 2 | CHASSIS, WARNING, DCX, S12,C0: Various non-critical hardware errors were observed: fault1:0xa, fault2:0x64 thresh1:0xa000000a.
In the example above blade in slot 12(S12) is impacted.
slotshow -m:
Slot   Blade Type     ID    Model Name     Status
  1     CP BLADE    175     CPX6           ENABLED
  2     CP BLADE    175     CPX6           ENABLED
  3     SW BLADE    178     FC32-48        ENABLED
  4     SW BLADE    178     FC32-48        ENABLED
  5     SW BLADE    178     FC32-48        ENABLED
  6     SW BLADE    178     FC32-48        ENABLED
  7     CORE BLADE  177     CR32-8         ENABLED
  8     CORE BLADE  177     CR32-8         ENABLED
  9     SW BLADE    178     FC32-48        ENABLED
 10     SW BLADE    178     FC32-48        ENABLED
 11     SW BLADE    178     FC32-48        ENABLED
 12     SW BLADE    178     FC32-48        ENABLED
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
