BES-53248 switch info not displayed under device-discovery
Applies to
- BES-53248 network switches with EFOS 3.7.0.4
- ONTAP 9.8P12, 9.9.1P10, 9.10P6
- MetroCluster IP (MCCIP)
Issue
- After EFOS upgrade to 3.7.0.4 on both BES-53248 switches, one controller in the MCCIP no longer displays cluster network switches in
device-discovery show
- Switch logs confirm that storage side ports are properly displayed under
show isdp neighbors
*************** show isdp neighbors *************** Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge, S - Switch, H - Host, I - IGMP, r - Repeater Device ID Intf Holdtime Capability Platform Port ID ------------------------ --------- --------- ---------- ---------------- --------- Node-01 0/9 150 H AFF-A220 e0b Node-02 0/10 149 H AFF-A220 e0b Switch-01 0/55 177 R S BES-53248 0/55 Switch-01 0/56 177 R S BES-53248 0/56
- Increasing checksum errors are observed under
cdpd show-stats
Cluster::*> run -node Node-01 cdpd show-statsRECEIVE Packets: 611k | Csum Errors: 366k | Unsupported Vers: 0 Invalid length: 0 | Malformed: 0 | Mem alloc fails: 0 Missing TLVs: 0 | Cache overflow: 0 | Received Own Adv: 0 Other errors: 0 | Unknown TLV: 0 | Ejected entries: 0 Eject failed: 0 | Bad Value: 0 TRANSMIT Packets: 76375 | Xmit fails: 0 | No hostname: 0 Packet truncated: 0 | Truncate fails: 0 | Mem alloc fails: 0 Other errors: 0
- Affected controller intermittently reports warnings such as the below for the switches
Thu Aug 25 13:29:06 +0200 [Node-01: client_common_RPC: csm.mismatchRemoteDevice:error]: CSM connection between source LIF 1023 and destination address xxx.xxx.xxx.xxx might not be optimal for session xxxxxxxxxxxxxxxx. The source is currently connected to - remote device and the destination is currently connected to Switch-01 remote device. Thu Aug 25 13:29:06 +0200 [Node-01: client_common_RPC: csm.mismatchRemoteDevice:error]: CSM connection between source LIF 1024 and destination address xxx.xxx.xxx.xxx might not be optimal for session xxxxxxxxxxxxxxxx. The source is currently connected to - remote device and the destination is currently connected to Switch-02 remote device. Thu Aug 25 13:29:06 +0200 [Node-01: client_common_RPC: csm.mismatchRemoteDevice:error]: CSM connection between source LIF 1023 and destination address xxx.xxx.xxx.xxx might not be optimal for session xxxxxxxxxxxxxxxx. The source is currently connected to - remote device and the destination is currently connected to Switch-01 remote device. Thu Aug 25 13:29:06 +0200 [Node-01: client_common_RPC: csm.mismatchRemoteDevice:error]: CSM connection between source LIF 1024 and destination address xxx.xxx.xxx.xxx might not be optimal for session xxxxxxxxxxxxxxxx. The source is currently connected to - remote device and the destination is currently connected to Switch-02 remote device. Thu Aug 25 13:29:06 +0200 [Node-01: client_common_RPC: csm.mismatchRemoteDevice:error]: CSM connection between source LIF 1023 and destination address xxx.xxx.xxx.xxx might not be optimal for session xxxxxxxxxxxxxxxx. The source is currently connected to - remote device and the destination is currently connected to Switch-01 remote device. Thu Aug 25 13:29:06 +0200 [Node-01: client_common_RPC: csm.mismatchRemoteDevice:error]: CSM connection between source LIF 1024 and destination address xxx.xxx.xxx.xxx might not be optimal for session xxxxxxxxxxxxxxxx. The source is currently connected to - remote device and the destination is currently connected to Switch-02 remote device.
- Collected packet-traces from the switches confirm that Cisco Discovery Protocol (CDP) packets are being forwarded to the storage correctly
- Migrating the cluster LIF between nodes and then disabling and re-enabling the ports makes no difference
- Performing a takeover and giveback between nodes doesn't help
- Updating ONTAP to version 9.9.1P10 or 9.10P6 leads to no change
- Physical inspection of the storage and switches confirms all ports and cables are working correctly
