NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
NetApp Knowledge Base
BES-53248 RCF configuration validation fails while copying the script
260
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
BES-53248 cluster switches
Issue
BES 53248 cluster switch reports validation error while trying to copy the RCF script:
(Switch)#copy http://172.19.2.1/RCF-Cluster-HA.txt nvram:script RCF-Cluster-HA.scr
Management access will be blocked for the duration of the transfer
Are you sure you want to start? (y/n) y
HTTP Configuration Script transfer starting...
Validating configuration script...
Configuration script validation failed.
Following lines in the script may have problem:
Line 41:: passwords lock-out 0
Line 55:: police-simple rate-percent 60 64 conform-action transmit violate-action transmit
Line 59:: police-simple rate-percent 60 64 conform-action transmit violate-action transmit
Line 68:: police-simple rate-percent 60 64 conform-action transmit violate-action transmit
Line 72:: police-simple rate-percent 60 64 conform-action transmit violate-action transmit
Total error Lines :: 5
The file being downloaded has potential problems.
Do you want to save this file? (y/n)
New to NetApp?
Scan to view the article on your device
