NetApp Knowledge Base
Transferring firmware to the CN1610 using SCP fails due to host sshd_config file
171
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
Applies to
NetApp CN1610 switch
Issue
'File transfer failed!' reported when attempting to copy a file to the CN1610 switch using SCP.
(CN1610) #copy scp://user1@10.1.1.1//tmp/NetApp...10_1.2.0.7.stk active
Remote Password:*********
Mode........................................... SCP
Set Server IP.................................. 10.1.1.1
Path........................................... /tmp/
Filename....................................... NetApp_CN1610_1.2.0.7.stk
Data Type...................................... Code
Destination Filename........................... active
Management access will be blocked for the duration of the transfer
Are you sure you want to start? (y/n) y
New to NetApp?
