NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
Node accessible via HA-IC, but cluster access failed during cluster switch migration
76
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
Applies to
  • Switchless cluster to BES-53248 cluster switch conversion
Issue
  • Following the below procedure to migrate from 2 node switchless cluster to switched cluster with BES-53248 cluster switches:
     Migrate to a switched NetApp cluster environment using Broadcom-supported BES-53248 cluster switches
  • Each node has e0a cluster port connected to new cluster switch cs1
  • The e0b cluster ports are still connected to each other
  • There is a link error (port flapping due to faulty cable) on one of the links connected to the new switch
  • The following is seen on the affected node:
cluster1::> storage failover show
                              Takeover
Node           Partner        Possible State Description
cluster1-01    cluster1-02    true     Connected to cluster1-02.
cluster1-02    cluster1-01    -        Up. Node accessible via HA-IC, but
  • Data may stop being served by this node or by indirect access to this node
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
