NetApp Knowledge Base
Multiple ESXi hosts on Cisco UCS lost datastore connectivity
560
Visibility:
Votes:
1
Category:
fabric-interconnect-and-management-switches
Specialty:
san
Last Updated:
Applies to
  • VMware ESXi
  • Cisco UCS-FI-6332-16UP >= 4.0
  • Brocade FabricOS (FOS)
Issue
  • On ESXi, vobd.log lists LUN resets, path loss, All Path Down (APD), Permanent Device Loss (PDL) event entries against multiple (all) datastores:
    2021-11-02T12:54:31.826Z: [scsiCorrelator] 1068996446us: [vob.scsi.scsipath.pathstate.dead] scsiPath vmhba1:C0:T25:L10 changed state from on
    2021-11-02T12:54:31.830Z: [scsiCorrelator] 1069000506us: [vob.scsi.scsipath.pathstate.dead] scsiPath vmhba1:C0:T25:L4 changed state from on
    2021-11-02T12:57:17.144Z: [scsiCorrelator] 1234311968us: [vob.scsi.scsipath.por] Power-on Reset occurred on naa.600a09803830376643xxxx
    2021-11-02T12:58:53.367Z: [scsiCorrelator] 1330557897us: [esx.problem.storage.connectivity.lost] Lost connectivity to storage device naa.600a09803830376643xxxxx. Path vmhba0:C0:T21:L4 is down. Affected datastores: Unknown.
    2021-11-02T13:01:13.367Z: [APDCorrelator] 1470530196us: [vob.storage.apd.timeout] Device or filesystem with identifier [naa.600a0980383037654xxxxx] has entered the All Paths Down Timeout state after being in the All Paths Down state for 140 seconds. I/Os will now be fast failed.
    2021-11-02T13:06:13.119Z: [APDCorrelator] 1770276511us: [vob.storage.apd.start] Device or filesystem with identifier [naa.600a09803830376643xxxx] has entered the All Paths Down state.
    2021-11-02T13:06:13.119Z: [APDCorrelator] 1770309617us: [esx.problem.storage.apd.start] Device or filesystem with identifier [naa.600a09803830376643xxxx] has entered the All Paths Down state.
    2021-11-02T13:06:13.120Z: [scsiCorrelator] 1770310964us: [esx.problem.storage.connectivity.lost] Lost connectivity to storage device naa.600a09803830376643xxxxx. Path vmhba0:C0:T27:L8 is down. Affected datastores: Unknown.
  • On FOS porterrshow indicates significant increase of c3 timeouts error counters compared to other counters, whereas RX are the result of the TX errors.
    porterrshow        :
              frames     [...]  disc   link   loss   loss   frjt   fbsy  c3timeout    pcs    uncor
           tx     rx     [...]  c3    fail    sync   sig                  tx    rx     err    err
      0:    4.0g 739.0m  [...]  42.3k   0      0      0      0      0      0     42.0k   0      0
      1:  327.2m   2.3g  [...]  16.2k   0      0      0      0      0      0     16.1k   0      0
     22:   13.6k  25.6k  [...]  58      0      0      0      0      0      0     58      0      0
     23:   12.9k  24.8k  [...]   6      0      0      0      0      0      0      6      0      0
     28:  189.4m   8.7m  [...]   1.1k 750      0      1      0      0      1.1k   5      0      0
     29:   87.8m   6.5m  [...]   1.2k 750      0      1      0      0      1.2k   3      0      0
     30:   33.1m   6.0m  [...]   3.0k 750      0      1      0      0      3.0k   1      1      0
     31:   98.8m  21.1m  [...]   1.3k 750      0      1      0      0      1.3k   1      1      0
     32:    1.0g   1.1g  [...]   1.6k   0      0      0      0      0      0      1.6k   0      0
     33:    1.0g   1.1g  [...] 950      0      0      0      0      0      0    947      0      0
     34:  530.7m   1.7g  [...]   2.0k   0      0      0      0      0      0      2.0k   0      0
     35:  549.5m   2.2g  [...]   1.7k   0      0      0      0      0      0      1.7k   0      0
    • The devices connected to the ports with c3 timeouts (tx) can be identified via "nsshow" for further investigation of the affected link.
      N    0c1c00;      3;pn;pn 0x00000000
      SCR: None
      IP address: ip
      PortSymb: [22] "UCSname-A:fc1/1."
      NodeSymb: [15] "UCSname-A"
      Fabric Port Name: pn
      Permanent Port Name: pn
      Device type: Physical Unknown(initiator/target)
      Port Index: 28
  • On FOS, errdump -a states correlating timeouts and link resets:
    2021/11/02-13:01:36, [C3-1014], 62547, CHASSIS, WARNING, DS_6510B,  Link Reset on Port S0,P31(45) vc_no=0 crd(s)lost=64 auto trigger.
    2021/11/02-13:01:37, [C3-1014], 62548, CHASSIS, WARNING, DS_6510B,  Link Reset on Port S0,P28(40) vc_no=0 crd(s)lost=64 auto trigger.
    2021/11/02-13:01:37, [C3-1014], 62549, CHASSIS, WARNING, DS_6510B,  Link Reset on Port S0,P30(42) vc_no=0 crd(s)lost=64 auto trigger.
    2021/11/02-13:01:37, [AN-1014], 62550, FID 128, INFO, switchname, Frame timeout detected, tx port 28 rx port 0, sid b2201, did c1c0b, timestamp 2021-11-02 13:01:37 .
    2021/11/02-13:01:37, [AN-1014], 62559, FID 128, INFO, switchname, Frame timeout detected, tx port 30 rx port 34, sid c2201, did c1e08, timestamp 2021-11-02 13:01:37 .
    2021/11/02-13:01:38, [AN-1014], 62560, FID 128, INFO, switchname, Frame timeout detected, tx port 31 rx port 0, sid b2201, did c1f17, timestamp 2021-11-02 13:01:38 .
  • The fabric partner exhibits the same on ports 28 and 30
    porterrshow        :
     28:    2.0m 602.4k  [...]  49.5k  24      0      1      0      0     49.3k 104     17      0
     29:   54.7m   4.3m  [...]  11     24      0      0      0      0      0      0      0      0
     30:    3.3m 104.7k  [...]  34.2k  24      0      0      0      0     34.0k  98     49      0
     31:  348.9m  32.9m  [...]   4     24      0      9.5k   0      0      0      0      0      0
New to NetApp?
