NetApp Knowledgebase
How to upgrade Brocade switch firmware
4,339
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
san
Last Updated:
Applies to
  • SAN
  • Brocade Fibre Channel switches
  • FlexPod
This article covers the procedure of upgrading firmware on a Brocade switch.
Procedure
This procedure does not apply to fabric-attached MetroCluster.
Notes:
  • This procedure requires an FTP service running on a Windows or UNIX workstation. Microsoft IIS is tested and supported by Brocade.
  • For older versions of Fabric OS, a stepped upgrade may be required. See the Brocade Fabric OS Target Path Selection Guide or refer to this guide for more details.
Example:
v7.4.x —> v8.0.x —> v8.1.x
  1. Obtain the firmware version; see How to obtain Brocade Fabric OS from NetApp
  2. Ensure the configuration of the switch is backed up prior to the upgrade via the configupload command.
  3. Upgrade the switch
    1. Verify that the workstation can ping the Brocade switch
    2. Locate the extracted firmware directory structure in ftproot
    3. Run the firmwaredownload command on the brocade switch. Firmware update can be done through the CLI or the web interface
    4. Provide the workstation IP address
    5. Login as anonymous or a valid FTP user
    6. Provide the path to the firmware directory relative to the ftproot and type release.plist.
Example:
For v8.4.0, the path is as follows:  fw/v8.4.0/release.plist
Note: The release.plist file is not listed in the root of the firmware directory (/fw/v8.4.0), but the firmware will use the appropriate release.plist file in the child directory, based on its switch type.
  1. Switch will update the secondary firmware, reboot, update the primary, then reboot for the final time.
  2. Once completed, confirm by typing version and firmwareshow.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
