How to obtain older versions of Brocade Fabric OS software/firmware not available through the Broadcom Assist Portal
Applies to
Brocade Fabric OS 7.4.0* or lower
- Fabric OS firmware that is end of support (EOS) is not available for direct download through the NetApp support site.
- If a switch is running EOS firmware and requires a stepped upgrade, then the procedure below can be used to obtain it.
