NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
Error! in configuration script file at line number XX when applying a new RCF
981
Visibility:
Votes:
1
Category:
fabric-interconnect-and-management-switches
Specialty:
network
Last Updated:
Applies to
Cluster switch Broadcom BES-53248
Issue
Error applying a new RCF file to a Broadcom BES-53248. Example:
(CS1) #script apply BES-53248_RCF_v1.6-Cluster-HA.scr
 Are you sure you want to apply the configuration script? (y/n) y
 config
 match cos 5
 Unrecognized command : match cos 5
 Error! in configuration script file at line number 40.
 CLI Command :: match cos 5.
 Aborting script.
 Execution of configuration script 'BES-53248_RCF_v1.6-Cluster-HA.scr' could not be completed.
 WARNING:
 The running configuration may not be the desired configuration. You might want to reload the saved configuration.
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
