If you missed the pre-registration for NetApp MS Azure AD B2C Go Live, when you log in, the new login prompt will offer the option to register. Please note that access to your NetApp data may take up to 1 hour. Need assistance? Complete this form and select “Registration Issue” as the Feedback Category.
NetApp Knowledge Base
Data outage during switched to switchless conversion
74
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
core
Last Updated:
Applies to
  • FAS8040
  • Switched cluster to 2 node switchless cluster conversion
  • ONTAP 9.7P11
Issue
EMS log shows following
[Node-A: vifmgr: vifmgr.lifsuccessfullymoved:notice]: LIF Node-A_clus1 (on virtual server 4294967293), IP address 169.254.49.239, is now hosted on node Node-A, port e0a.
[Node-A: vifmgr: vifmgr.lifmoved.linkdown:notice]: LIF Node-A_clus1 (on virtual server 4294967293), IP address 169.254.49.239, is being moved to node Node-A, port e0a.
[Node-A: mgwd: clus.net.switchlessInv:notice]: One or more cluster ports are directly wired to a cluster port on another node, but the "switchless-cluster" option is not enabled.
[Node-A: vifmgr: vifmgr.dbase.checkerror:alert]: VIFMgr experienced an error verifying cluster database consistency. Some LIFs might not be hosted properly as a result.
[Node-A: vifmgr: vifmgr.startup.failover.err:alert]: VIFMgr encountered errors during startup.
  • Then the data LIFs get removed from the physical ports they are hosted on
[Node-A: vifmgr: vifmgr.lifBeingRemoved:notice]: LIF Data-Vserver1-Lif1 (on virtual server 16), IP address x.x.x.x, is being removed from node Node-A, port e0e
[Node-A: vifmgr: vifmgr.lifBeingRemoved:notice]: LIF Data-Vserver1-Lif2 (on virtual server 12), IP address x.x.x.x, is being removed from node Node-A, port e0e.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
