Brocade G610 rebooted unexpectedly
Applies to
- Brocade G610
- FabOS 8.2.2
Issue
- Brocade G610 rebooted unexpectedly multiple times without obvious reasons
errdump -a
2022/02/08-19:04:19, [HAM-1004], 238, CHASSIS, INFO, BrocadeG610, Processor rebooted - Reset.
2022/02/28-09:36:49, [HAM-1004], 246, CHASSIS, INFO, BrocadeG610, Processor rebooted - Reset.
2022/03/23-09:55:31, [HAM-1004], 261, CHASSIS, INFO, BrocadeG610, Processor rebooted - Reset.
psshow
Power Supply #1 is OK
fanshow
Fan 1 is Ok, speed is 7425 RPM
Fan 2 is Ok, speed is 7345 RPM
Fan 3 is Ok, speed is 7425 RPM
Fan 4 is Ok, speed is 7425 RPM
sensorshow
sensor 1: (Temperature) is Ok, value is 23 C
sensor 2: (Temperature) is Ok, value is 23 C
sensor 3: (Temperature) is Ok, value is 26 C
sensor 4: (Temperature) is Ok, value is 25 C
sensor 5: (Temperature) is Ok, value is 21 C
sensor 6: (Temperature) is Ok, value is 19 C
sensor 7: (Temperature) is Ok, value is 25 C
sensor 8: (Temperature) is Ok, value is 22 C
sensor 9: (Temperature) is Ok, value is 37 C
sensor 10: (Fan ) is Ok,speed is 7425 RPM
sensor 11: (Fan ) is Ok,speed is 7345 RPM
sensor 12: (Fan ) is Ok,speed is 7425 RPM
sensor 13: (Fan ) is Ok,speed is 7425 RPM
sensor 14: (Power Supply) is Ok
- Verified power cable is seated correctly and verify health status of components providing switch with power (sockets, lines, cables, UPS, etc.).
- Issue persists even after power cable and socket were swapped
- Other components on the same Uninterruptible Power Supply (UPS) / circuit are not affected.
