Brocade: Messages Warning - C4-1006 and Critical C4-1010
Applies to
- Brocade DCX
- X6 directors
Issue
The customer observes a lot of error on Brocade DCX/X6 directors without any impact:
2020/01/22-19:07:06, [C4-1010], 433, SLOT 2 | CHASSIS, CRITICAL, DCX, S12,C0: Above normal hardware errors were observed: fault1:0x1, fault2:0x64 thresh2:0xb0000064.
2020/01/22-19:20:41, [C4-1006], 434, SLOT 2 | CHASSIS, WARNING, DCX, S12,C0: Various non-critical hardware errors were observed: fault1:0xa, fault2:0x64 thresh1:0xa000000a.
In the example above blade in slot 12(S12) is impacted.
slotshow -m:
Slot Blade Type ID Model Name Status
1 CP BLADE 175 CPX6 ENABLED
2 CP BLADE 175 CPX6 ENABLED
3 SW BLADE 178 FC32-48 ENABLED
4 SW BLADE 178 FC32-48 ENABLED
5 SW BLADE 178 FC32-48 ENABLED
6 SW BLADE 178 FC32-48 ENABLED
7 CORE BLADE 177 CR32-8 ENABLED
8 CORE BLADE 177 CR32-8 ENABLED
9 SW BLADE 178 FC32-48 ENABLED
10 SW BLADE 178 FC32-48 ENABLED
11 SW BLADE 178 FC32-48 ENABLED
12 SW BLADE 178 FC32-48 ENABLED
