NetApp Knowledge Base
BES-53248 RCF configuration validation fails while copying the script
52
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
BES-53248 cluster switches
Issue
BES 53248 cluster switch reports validation error while trying to copy the RCF script:
(Switch)#copy http://172.19.2.1/RCF-Cluster-HA.txt nvram:script RCF-Cluster-HA.scr
Management access will be blocked for the duration of the transfer
Are you sure you want to start? (y/n) y
HTTP Configuration Script transfer starting...
Validating configuration script...
Configuration script validation failed.
Following lines in the script may have problem:
Line 41:: passwords lock-out 0
Line 55:: police-simple rate-percent 60 64 conform-action transmit violate-action transmit
Line 59:: police-simple rate-percent 60 64 conform-action transmit violate-action transmit
Line 68:: police-simple rate-percent 60 64 conform-action transmit violate-action transmit
Line 72:: police-simple rate-percent 60 64 conform-action transmit violate-action transmit
Total error Lines :: 5
The file being downloaded has potential problems.
Do you want to save this file? (y/n)
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
