NetApp Knowledge Base
After switch reboot, CLUSTER NETWORK DEGRADED ALERT seen in ASUP
153
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
network
Last Updated:
Applies to
CN1610
Issue
  • CN1610 switches rebooted after a power outage or maintenance.
  • The NetApp system reports (CLUSTER NETWORK DEGRADED)
  • If using ISL LAG (link aggregate), you may see this ASUP alert:(Health Monitor process cshm: SwitchIfIslDownWarn_Alert[<switch_name>/<LAG_name>]) ALERT
  • Switch show tech-support reports ISL ports disabled and down:
0/13      PC Mbr Disable   10G Full              Down   Enable  Enable long
0/14      PC Mbr Disable   10G Full              Down   Enable  Enable long
0/15      PC Mbr Disable   10G Full              Down   Enable  Enable long
0/16      PC Mbr Disable   10G Full              Down   Enable  Enable long
  • In the switch's show running-config we see shutdown on all ISL ports
    interface 0/13
    shutdown
    description 'ISL member port 13'
    mtu 9216
    exit
    interface 0/14
    shutdown
    description 'ISL member port 14'
    mtu 9216
    exit
    interface 0/15
    shutdown
    description 'ISL member port 15'
    mtu 9216
    exit
    interface 0/16
    shutdown
    description 'ISL member port 16'
    mtu 9216
    exit
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
