NetApp Knowledgebase
The Brocade switch shows the WARNING: Link Reset on Port
Applies to
Brocade switch
Issue
  • The Brocade switch shows the Link Reset on Port
2020/04/08-21:35:56, [C3-1014], 2556, CHASSIS, WARNING, Brocade6510,  Link Reset on Port S0,P8(12) vc_no=0 crd(s)lost=12 auto trigger.
2020/04/09-09:03:42, [C3-1014], 2557, CHASSIS, WARNING, Brocade6510,  Link Reset on Port S0,P8(12) vc_no=0 crd(s)lost=12 auto trigger.
  • The Brocade TX Power of RX Power is lower than 300 uWatts on the command sfpshow -all
Port  8:
Identifier:  3    SFP
Connector:   7    LC
Transceiver: 7004404000000000 4,8,16_Gbps M5 sw Short_dist
Encoding:    6    64B66B
Baud Rate:   140  (units 100 megabaud)
Length 9u:   0    (units km)
Length 9u:   0    (units 100 meters)
Length 50u (OM2):  3    (units 10 meters)
Length 50u (OM3):  10   (units 10 meters)
Length 62.5u:0    (units 10 meters)
Length Cu:   0    (units 1 meter)
Vendor Name: BROCADE
Vendor OUI:  00:05:1e
Vendor PN:   57-0000088-01
Vendor Rev:  A
Wavelength:  850  (units nm)
Options:     003a Loss_of_Sig,Tx_Fault,Tx_Disable
BR Max:      0
BR Min:      0
Serial No:   HAF6182300004BC
Date Code:   180605
DD Type:     0x68
Enh Options: 0xfa
Status/Ctrl: 0x0
Pwr On Time: 1.24 years (10834 hours)
E-Wrap Control: 0
O-Wrap Control: 0
Alarm flags[0,1] = 0x5, 0x40
Warn Flags[0,1] = 0x5, 0x40
Temperature: 55      Centigrade
Current:     7.506   mAmps
Voltage:     3314.0  mVolts
RX Power:    -2.8    dBm (520.8uW)
TX Power:    -10.3   dBm (92.4  uW)
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
