RCF Improperly Applied to Cluster Network Switch Requiring RCF Revert
Applies to
Cisco Nexus (NX) Cluster Network Switches
Issue
- An RCF has been improperly applied, and is noticed when reviewing the running configuration with the
show running-config
command; attempts to re-apply the correct RCF do not resolve the issue - Latency may be seen across cluster interconnect
- Data may stop being served due to indirect traffic
- Cluster network degraded Autosupport callhomes may be generated on a daily basis due to the following cluster network ping loss errors between all nodes in the cluster
HA Group Notification (CLUSTER NETWORK DEGRADED) ALERT
3/11/2022 17:49:59 node-01 ALERT vifmgr.cluscheck.ctdpktloss: Continued packet loss when pinging from cluster lif node-01_clus2 (node node-01) to cluster lif node-02_clus1 (node node-02).
