NetApp Knowledge Base
How to obtain older versions of Brocade Fabric OS software/firmware not available through the Broadcom Assist Portal
3,528
Visibility:
Votes:
2
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
Applies to
Brocade Fabric OS versions removed from the Brocade Assist Portal
  • Fabric OS firmware that is end of support (EOS) is not available for direct download through the NetApp support site.
  • If a switch is running EOS firmware and requires a stepped upgrade, then the procedure below can be used to obtain it.
New to NetApp?
