NetApp Knowledge Base
Unable to re-establish ISL E-port link after DWDM maintenance
485
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
brocade
Last Updated:
Applies to
  • FCP
  • Brocade
Issue
  • Unable to re-establish a connection between switches using wavelength-division multiplexing (DWDM) equipment after DWDM maintenance and reboots
    • Using a known good DWDM channel does not work
    • Port and DWDM diagnostics do not show any issues
    • Using new switch ports does not resolve the issue
Example:
LS Disabled (Authentication Rejected) with RAS error
authentication-reject was received with code 'Authentication Failure' and explanation 'Authentication Failed'.
New to NetApp?
