NetApp Knowledge Base
After switch reboot, CLUSTER NETWORK DEGRADED ALERT seen SwitchIfIslDownWarn_Alert
676
Visibility:
Votes:
1
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • CN1610 cluster switch
  • BES-53248 cluster switch
Issue
  • Switch rebooted after a power outage or maintenance.
  • The system reports the following CLUSTER NETWORK DEGRADED alerts in event logs:
[Node-01: vifmgr: callhome.clus.net.degraded:alert]: Call home for CLUSTER NETWORK DEGRADED: Total Packet Loss - Ping failures detected between Node-01_clus2 ( 169.XXX.XX.XXX ) on Node-01 and Node-04_clus1 ( 169.XXX.XX.XXX ) on Node-04
  • If using ISL LAG (link aggregate), you may see this ASUP alert:(Health Monitor process cshm: SwitchIfIslDownWarn_Alert[<switch_name>/<LAG_name>]) ALERT
  • In event logs:
[Node-04: cshmd: hm.alert.raised:alert]: Alert Id = SwitchIfIslDownWarn_Alert , Alerting Resource = cluster-sw1/ Link Aggregate 1 raised by monitor cluster-switch
  • The switch health is degraded:
eu10380sc1::> system health subsystem show
Subsystem         Health
SAS-connect       ok
Environment       ok
Memory            ok
Service-Processor ok
Switch-Health     degraded
CIFS-NDO          ok
Motherboard       ok
  • Switch show tech-support reports ISL ports disabled and down:
Switch# show port all
                 Admin     Physical   Physical   Link   Link    LACP   Actor
Intf      Type   Mode      Mode       Status     Status Trap    Mode   Timeout
0/13      PC Mbr Disable   10G Full              Down   Enable  Enable long
0/14      PC Mbr Disable   10G Full              Down   Enable  Enable long
0/15      PC Mbr Disable   10G Full              Down   Enable  Enable long
0/16      PC Mbr Disable   10G Full              Down   Enable  Enable long
  • In the show running-config output of the switch, we see that all the ISL ports are shutdown:
    interface 0/13
    shutdown
    description 'ISL member port 13'
    mtu 9216
    exit
    interface 0/14
    shutdown
    description 'ISL member port 14'
    mtu 9216
    exit
    interface 0/15
    shutdown
    description 'ISL member port 15'
    mtu 9216
    exit
    interface 0/16
    shutdown
    description 'ISL member port 16'
    mtu 9216
    exit
New to NetApp?
