What baud rate do NetApp controller serial console connections support?
Applies to
- FAS systems
- AFF systems
- Console Port
- Micro-USB Serial
- RJ45 Serial
Answer
- All new NetApp controllers operate at 115200 baud1. The change was first made on the FAS8200 and AFF A300 platforms in BIOS release 10.0
- Previous generation controllers: FAS22xx, FAS25xx, FAS32xx, FAS62xx and FAS80xx - operate at 9600 baud
- The speed is hard-coded into the BIOS of the motherboard
Note1: baud rate and bit rate are synonymous in the context of a simple (i.e., unmodulated) serial interface.
