Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
nfsv4 mount  using kerberos 5p fails after upgrading to ontap 9.9.1
59
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
  • Ontap 9.9.1
  • NFS
  • kerberos 5p
Issue
When an export policy rule has been configued to allow only kerberos 5p connections and the system is running 9.9.1 or later.
  • Is necessary to specify krb5p mount option on the client for mont to be successful as as security flavor negotiation would not work properly
  • Automount configurations may not allow mounting nfs resources
If NFS sktraces are enabled the following subsequent lines would appear in sktrace.log when the issue is hit
[1:0] Nfs4Req_5:  CurrentFlags before NGProcessExportCheck: cfs=0x1004, EAI=0x0
[1:0] Nfs4Req_5:  Result EXPORT_NOACCESS: Result=3106
New to NetApp?
Scan to view the article on your device
