NetApp Knowledge Base
e0M and e0P port repeat Link Down/Up
497
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS2552
  • ONTAP8.3 P2 Cluster Mode
Issue
The e0M and e0P port repeat Link Down/Up as below.
Example:
[?] Tue Mar 10 11:40:48 JST [hostname: ltm_services: snmp.link.down:info]: Interface 7 is down.
[?] Tue Mar 10 11:40:48 JST [hostname: ltm_services: netif.linkDown:info]: Ethernet e0M: Link down, check cable.
[?] Tue Mar 10 11:40:49 JST [hostname: ltm_services: snmp.link.down:info]: Interface 8 is down.
[?] Tue Mar 10 11:40:49 JST [hostname: ltm_services: netif.linkDown:info]: Ethernet e0P: Link down, check cable.
[?] Tue Mar 10 11:40:51 JST [hostname: vifmgr: vifmgr.portdown:info]: A link down event was received on node hostname, port e0M.
[?] Tue Mar 10 11:40:51 JST [hostname: vifmgr: vifmgr.lifdown.noports:error]: LIF hostname_mgmt1 (on virtual server 4294967295), IP address 172.30.254.171, currently cannot be hosted on node hostname, port e0M, or anywhere else, and is being marked as down.
[?] Tue Mar 10 11:40:51 JST [hostname: ltm_services: snmp.link.up:info]: Interface 7 is up
[?] Tue Mar 10 11:40:51 JST [hostname: ltm_services: netif.linkUp:info]: Ethernet e0M: Link up.
[?] Tue Mar 10 11:40:51 JST [hostname: vifmgr: vifmgr.lifBeingRemoved:info]: LIF hostname_mgmt1 (on virtual server 4294967295), IP address 172.30.254.171, is being removed from node hostname, port e0M.
[?] Tue Mar 10 11:40:52 JST [hostname: ltm_services: snmp.link.up:info]: Interface 8 is up
[?] Tue Mar 10 11:40:52 JST [hostname: ltm_services: netif.linkUp:info]: Ethernet e0P: Link up.
[?] Tue Mar 10 11:40:52 JST [hostname: ltm_services: snmp.link.down:info]: Interface 7 is down.
[?] Tue Mar 10 11:40:52 JST [hostname: ltm_services: netif.linkDown:info]: Ethernet e0M: Link down, check cable.
[?] Tue Mar 10 11:40:52 JST [hostname: dsa_vmm: hamsg.connectSucceeded:debug]: params: {'remoteID': '00036bb8950411e584e377f7cdb4a70d'}
[?] Tue Mar 10 11:40:53 JST [hostname: ltm_services: snmp.link.down:info]: Interface 8 is down.
[?] Tue Mar 10 11:40:53 JST [hostname: ltm_services: netif.linkDown:info]: Ethernet e0P: Link down, check cable.
[?] Tue Mar 10 11:40:54 JST [hostname: vifmgr: vifmgr.portdown:info]: A link down event was received on node hostname, port e0M.
[?] Tue Mar 10 11:40:54 JST [hostname: vifmgr: vifmgr.lifmoved.linkdown:info]: LIF hostname_mgmt1 (on virtual server 4294967295), IP address 172.30.254.171, is being moved to node hostname, port e0M.
[?] Tue Mar 10 11:40:55 JST [hostname: ltm_services: snmp.link.up:info]: Interface 7 is up
[?] Tue Mar 10 11:40:55 JST [hostname: ltm_services: netif.linkUp:info]: Ethernet e0M: Link up.
[?] Tue Mar 10 11:40:56 JST [hostname: ltm_services: snmp.link.down:info]: Interface 7 is down.
[?] Tue Mar 10 11:40:56 JST [hostname: ltm_services: netif.linkDown:info]: Ethernet e0M: Link down, check cable.
[?] Tue Mar 10 11:40:58 JST [hostname: vifmgr: vifmgr.portdown:info]: A link down event was received on node hostname, port e0M.
[?] Tue Mar 10 11:40:58 JST [hostname: vifmgr: vifmgr.lifmoved.linkdown:info]: LIF hostname_mgmt1 (on virtual server 4294967295), IP address 172.30.254.171, is being moved to node hostname, port e0M.
[?] Tue Mar 10 11:40:59 JST [hostname: ltm_services: snmp.link.up:info]: Interface 7 is up
[?] Tue Mar 10 11:40:59 JST [hostname: ltm_services: netif.linkUp:info]: Ethernet e0M: Link up.
[?] Tue Mar 10 11:41:00 JST [hostname: ltm_services: snmp.link.down:info]: Interface 7 is down.
[?] Tue Mar 10 11:41:00 JST [hostname: ltm_services: netif.linkDown:info]: Ethernet e0M: Link down, check cable.
[?] Tue Mar 10 11:41:02 JST [hostname: vifmgr: vifmgr.portdown:info]: A link down event was received on node hostname, port e0M.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
  • Was this article helpful?
