NetApp Knowledge Base
e0M and e0P port repeat Link Down/Up
1,210
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS2552
  • FAS2554
  • ONTAP8.3 P2 Cluster Mode
  • ONTAP 9
Issue
The e0M and e0P port repeat Link Down/Up as below.
Example:
[?] Tue Mar 10 11:40:48 JST [hostname: ltm_services: snmp.link.down:info]: Interface 7 is down.
[?] Tue Mar 10 11:40:48 JST [hostname: ltm_services: netif.linkDown:info]: Ethernet e0M: Link down, check cable.
[?] Tue Mar 10 11:40:49 JST [hostname: ltm_services: snmp.link.down:info]: Interface 8 is down.
[?] Tue Mar 10 11:40:49 JST [hostname: ltm_services: netif.linkDown:info]: Ethernet e0P: Link down, check cable.
[?] Tue Mar 10 11:40:51 JST [hostname: vifmgr: vifmgr.portdown:info]: A link down event was received on node hostname, port e0M.
[?] Tue Mar 10 11:40:51 JST [hostname: vifmgr: vifmgr.lifdown.noports:error]: LIF hostname_mgmt1 (on virtual server 4294967295), IP address 172.30.254.171, currently cannot be hosted on node hostname, port e0M, or anywhere else, and is being marked as down.
[?] Tue Mar 10 11:40:51 JST [hostname: ltm_services: snmp.link.up:info]: Interface 7 is up
[?] Tue Mar 10 11:40:51 JST [hostname: ltm_services: netif.linkUp:info]: Ethernet e0M: Link up.
[?] Tue Mar 10 11:40:51 JST [hostname: vifmgr: vifmgr.lifBeingRemoved:info]: LIF hostname_mgmt1 (on virtual server 4294967295), IP address 172.30.254.171, is being removed from node hostname, port e0M.
[?] Tue Mar 10 11:40:52 JST [hostname: ltm_services: snmp.link.up:info]: Interface 8 is up
[?] Tue Mar 10 11:40:52 JST [hostname: ltm_services: netif.linkUp:info]: Ethernet e0P: Link up.
[?] Tue Mar 10 11:40:52 JST [hostname: ltm_services: snmp.link.down:info]: Interface 7 is down.
[?] Tue Mar 10 11:40:52 JST [hostname: ltm_services: netif.linkDown:info]: Ethernet e0M: Link down, check cable.
[?] Tue Mar 10 11:40:52 JST [hostname: dsa_vmm: hamsg.connectSucceeded:debug]: params: {'remoteID': '00036bb8950411e584e377f7cdb4a70d'}
[?] Tue Mar 10 11:40:53 JST [hostname: ltm_services: snmp.link.down:info]: Interface 8 is down.
[?] Tue Mar 10 11:40:53 JST [hostname: ltm_services: netif.linkDown:info]: Ethernet e0P: Link down, check cable.
[?] Tue Mar 10 11:40:54 JST [hostname: vifmgr: vifmgr.portdown:info]: A link down event was received on node hostname, port e0M.
[?] Tue Mar 10 11:40:54 JST [hostname: vifmgr: vifmgr.lifmoved.linkdown:info]: LIF hostname_mgmt1 (on virtual server 4294967295), IP address 172.30.254.171, is being moved to node hostname, port e0M.
[?] Tue Mar 10 11:40:55 JST [hostname: ltm_services: snmp.link.up:info]: Interface 7 is up
[?] Tue Mar 10 11:40:55 JST [hostname: ltm_services: netif.linkUp:info]: Ethernet e0M: Link up.
[?] Tue Mar 10 11:40:56 JST [hostname: ltm_services: snmp.link.down:info]: Interface 7 is down.
[?] Tue Mar 10 11:40:56 JST [hostname: ltm_services: netif.linkDown:info]: Ethernet e0M: Link down, check cable.
[?] Tue Mar 10 11:40:58 JST [hostname: vifmgr: vifmgr.portdown:info]: A link down event was received on node hostname, port e0M.
[?] Tue Mar 10 11:40:58 JST [hostname: vifmgr: vifmgr.lifmoved.linkdown:info]: LIF hostname_mgmt1 (on virtual server 4294967295), IP address 172.30.254.171, is being moved to node hostname, port e0M.
[?] Tue Mar 10 11:40:59 JST [hostname: ltm_services: snmp.link.up:info]: Interface 7 is up
[?] Tue Mar 10 11:40:59 JST [hostname: ltm_services: netif.linkUp:info]: Ethernet e0M: Link up.
[?] Tue Mar 10 11:41:00 JST [hostname: ltm_services: snmp.link.down:info]: Interface 7 is down.
[?] Tue Mar 10 11:41:00 JST [hostname: ltm_services: netif.linkDown:info]: Ethernet e0M: Link down, check cable.
[?] Tue Mar 10 11:41:02 JST [hostname: vifmgr: vifmgr.portdown:info]: A link down event was received on node hostname, port e0M.
New to NetApp?
  • Was this article helpful?
