Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
"callhome.chassis.hitemp" error repeats every hour
229
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS2620
  • FAS2720
Issue
  • Chassis over temperature errors are reported every hour in the event logs:
[Node1: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: Ambient Temp is critical high (120 C).
[Node1: statd: monitor.shelf.fault:alert]: Critical fault reported on disk storage shelf attached to channel 0b. Check fans, power supplies, disks, and temperature sensors.
[Node1: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: Midplane 4 Temp is warning high (47 C).
[Node1: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: Midplane 3 Temp is warning high (47 C).
[Node1: monitor: monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too high..
[Node1: env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
  • Some of the sensors report over temperature on the shelf:
::> system node run -node <node> -command storage show fault
Enclosure Status: non-critical
Channel: 0b
Shelf: 0
Shelf Type: DS224-12
Product Serial Number: SHFFG1914000066
Module Type: IOM12E
Temperature Sensors:
Element Status         Status Bytes  Status Descriptions
  1: OK                01,00,33,00
  2: OK                01,00,39,00
  3: OK                01,00,39,00
  4: NONCRITICAL       03,00,44,04   OT WARNING
  5: NONCRITICAL       03,00,44,04   OT WARNING
  6: OK                01,00,3F,00
  • The over-temperature warnings can also be seen in the environment logs:
::> system node run -node <node> -command environment status
Temperature Sensor installed element list: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15; with error: 4, 5
    Shelf temperatures by element:
      [1] 31 C (87 F) (ambient)  Normal temperature range
      [2] 37 C (98 F)  Normal temperature range
      [3] 37 C (98 F)  Normal temperature range
      [4] 48 C (118 F) Overtemperature warning!
      [5] 48 C (118 F) Overtemperature warning!
      [6] 43 C (109 F)  Normal temperature range
  • From SP sensor logs:
Sensor Name              State          Current    Critical     Warning     Warning    Critical
                                        Reading       Low         Low         High       High
Temp Low Shutdown                           UP
Temp High Shutdown                          UP
SNMP Bad Fan Count                          OK
Chassis is Under Temp                       NO
Chassis is Over Temp                       YES
Midplane 4 Temp          warnhigh          47 C         0 C         5 C        47 C        52 C
Midplane 3 Temp          warnhigh          47 C         0 C         5 C        47 C        52 C
Midplane 2 Temp          normal            36 C         0 C         5 C        47 C        52 C
Midplane 1 Temp          normal            36 C         0 C         5 C        47 C        52 C
New to NetApp?
Scan to view the article on your device
  • Was this article helpful?
