Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
Why export policy does not restrict the client's access?
365
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
ONTAP 9
Issue
The set up is as below.
TEST-01::*> cifs share show -vserver test-fs02 -instance
Vserver: test-fs02
Share: test
CIFS Server NetBIOS Name: TEST-FS02
Path: /test
Share Properties: oplocks
                  browsable
                  changenotify
                  show-previous-versions
Symlink Properties: symlinks
File Mode Creation Mask: -
Directory Mode Creation Mask: -
Share Comment: -
Share ACL: Everyone / Full Control
File Attribute Cache Lifetime: -
Volume Name: test
Offline Files: manual
Vscan File-Operations Profile: standard
Maximum Tree Connections on Share: 4294967295
UNIX Group for File Create: -
Vserver: test-fs02
Share: qtree01
Path: /test/qtree01
                  browsable
                  changenotify
Share Comment: -
Volume Name: test
TEST-01::*> qtree show -vserver test-fs02 -volume test -instance
Vserver Name: test-fs02
Volume Name: test
Qtree Name: ""
Actual (Non-Junction) Qtree Path: /vol/test
Security Style: ntfs
Oplock Mode: enable
Unix Permissions: -
Qtree Id: 0
Qtree Status: normal
Export Policy: default
Is Export Policy Inherited: true
Volume Name: test
Qtree Name: qtree01
Actual (Non-Junction) Qtree Path: /vol/test/qtree01
Oplock Mode: enable
Unix Permissions: -
Qtree Id: 1
Export Policy: testpolicy
Is Export Policy Inherited: false
TEST-01::*> export-policy rule show -instance
Vserver: test-fs02
Policy Name: default
Rule Index: 1
Access Protocol: cifs
List of Client Match Hostnames, IP Addresses, Netgroups, or Domains: 0.0.0.0/0
RO Access Rule: any
RW Access Rule: any
User ID To Which Anonymous Users Are Mapped: 65534
Superuser Security Types: any
Honor SetUID Bits in SETATTR: true
Allow Creation of Devices: true
NTFS Unix Security Options: fail
Vserver NTFS Unix Security Options: use_export_policy
Change Ownership Mode: restricted
Vserver Change Ownership Mode: use_export_policy
Vserver: test-fs02
Policy Name: testpolicy
Rule Index: 1
List of Client Match Hostnames, IP Addresses, Netgroups, or Domains: 192.168.1.0/24
RO Access Rule: any
RW Access Rule: any
Superuser Security Types: none
After connecting windows client(192.168.2.1) Jumphost to the CIFS share "\\test-fs02\test", we can confirm folder "qtree01" under the folder "test".
Now the folder "qtree01" can be open even though the client IP address is not the same subnet as 192.168.1.x.
New to NetApp?
Scan to view the article on your device
