NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
NetApp Knowledge Base
Why did my SP/BMC reboot during a FW upgrade?
333
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • All Platforms
    • ASA systems
    • AFF systems
    • FAS systems
Answer
After the SP/BMC update is complete, the SP/BMC is automatically rebooted. You do not need to trigger an SP/BMC reboot manually.
  • This is expected behavior.
Firmware update will need to reboot the SP on completion. If your console connection is through the SP, it will be disconnected.
  • To display the SP/BMC update status, including whether an update is in progress, the update start and end time, and the completion percentage:
system service-processor image update-progress show -node node1
Node: node1
Latest SP Firmware Update Start Timestamp: 7/18/2017 12:22:37
Latest SP Firmware Update Percentage Done: 100
Latest SP Firmware Update End Timestamp: 7/18/2017 12:28:14
Is Update in Progress: no
  • Verify that the SP/BMC is online and running the intended version:
system service-processor show -node node1
Additional Information
  • This is covered on mysupport.NetApp.com Downloads >Firmware> System Firmware & Diagnostics
  • The download page will provide the steps to update your SP/BMC
Scan to view the article on your device
