NetApp Knowledge Base
Why HIC temp sensor shows with status disabled in A250?
248
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
  • AFF A250
  • HIC_Temp0, HIC_Temp1
Answer
  • Depending on the HIC type, the temp sensors on the card could be 0, 1 or 2.
  • If the sensor is not present on the card, the policy set the sensor in disabled state. It is expected behavior.
Additional Information
  • In node run -node * -command environment status we can see
HIC1 Temp1 disabled -- C 3 C 5 C 101 C 103 C
  • In sp-latest-ipmi output, the sensor will show like:
HIC1_TEMP1 | na | degrees C | na | 1.000 | 3.000 | 5.000 | 101.000 | 103.000 | 105.000
  • It can also be checked as disabled in AutoSupport section PLATFORM-SENSORS.xml
