NetApp Knowledgebase
Where is the serial number located on the filer?
131
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
FAS Systems
Answer
F7XX and F8XX
The serial number is located on the right side when you are facing the back of the storage system.
FAS2XX
The serial number is on the top left side when you are facing the back of the storage system.
FAS9XX
The serial number is located on the back of the storage system, facing up on the flange (bottom center).
FAS2XXX
The serial number is on the back of the storage system, at the top of the center module.
FAS3XXX
The serial number is located on the front of the storage system on the left side (remove bezel).
FAS32XX
The serial number is located on the back right side of the storage system under slot 2 on the motherboard.
FAS6XXX
FAS62XX
The serial number is on the back middle of the storage system under the Fiber and Ethernet ports.
Notes:
  • To locate the serial number in FilerView, go to Filer > Reports > System configuration.
  • To locate the serial number from the CLI, type: sysconfig -a
Additional Information
additionalInformation_text
