Where is the serial number located on a FAS Storage System?
Applies to
- FAS systems
- Serial number location
Answer
How to Identify the Serial Number for my ONTAP Platform?
Platform |
Serial number Location |
FAS2820Back of the storage system, below 0a port |
FAS9500FAS9000Back of the storage system, on the side of the PCM handle. |
FAS8300 / FAS8700Back of the storage system, right hand side under controller handle. |
FAS8200Back of the storage system, under slot 2. |
FAS8040, FAS8060, FAS8080Back of the storage system, bottom right |
FAS8020Back of the storage system, bottom right |
FAS62XXBack middle of the storage system under the Fibre and Ethernet ports. |
FAS500fBack of the storage system, between the power supply and serial console port |
FAS32X0Back right side of the storage system, Below the PCI card slots |
FAS2750Back of the storage system, above ports e0c/0c-e0d/0d. |
FAS2720Back of the storage system, above ports e0c/0c-e0d/0d |
FAS2650Back of the storage system, above ports e0c/0c-e0d/0d |
FAS2620Back of the storage system, above ports e0c/0c-e0d/0d |
FAS2554Back of the storage system, below ports e0c-e0f. |
FAS2552Back of the storage system, below ports e0c-e0f. |
FAS2520Back of the storage system, below ports e0c,e0d. |
FAS2240-4Back of the storage system, bottom left below ports 0a,0b |
FAS2220, FAS2240-2Back of the storage system, bottom left below ports 0a,0b |
Notes:
- Data ONTAP 7-mode - From the CLI, type:
sysconfig -a
- ONTAP 9 - From the CLI, type:
system controller show
Additional Information
Where is the serial number located on an AFF Storage System?
