Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
What is the smallest supported aggregate size in ONTAP 9?
405
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9.x
  • Aggregate
Answer
  • ONTAP 9 supports a minimum of 2 Disk with Raid4
  • Procedure:
    cluster::*> set advanced
    cluster::*> aggr create -aggregate SmallAggr -diskcount 2 -raidtype Raid4 -force-small-aggregate true
    Warning: You are creating an aggregate with fewer disks than recommended.
    Do you want to continue? {y|n}: y
    Info: The layout for aggregate "SmallAggr" on node "cluster-01" would be:
          First Plex
            RAID Group rg0, 2 disks (block checksum, raid4)
                                                               Usable Physical
              Position   Disk                      Type           Size     Size
              parity     VMw-1.7                   SSD               -        -
              data       VMw-1.8                   SSD         28.42GB  28.44GB
          Aggregate capacity available for volume use would be 25.58GB.
    [Job 107] Job succeeded: DONE
Additional Information
N/A
Scan to view the article on your device
