Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
What is the difference of the PSU alert in ASUP between Shelf and Node
350
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS8200
  • FAS2620
  • DS212C
Answer
  • Shelf like DS212C or DS2246 raises the following ASUP alerts when PSU failure.
Example:
(SHLEF POWER INTERRUPTED) ERROR
(SHELF_FAULT) ERROR
  • Node like FAS8200 or FAS6XXX and FAS3XXX raises the following ASUP alerts when PSU failure.
Example:
(CHASSIS POWER SUPPLY OFF:PS1) ERROR
(CHASSIS POWER SUPPLY DEGRADED:PS1)ERROR
  • Node like FAS2XXX has onboard IOM and internal shelf, so it raises the following ASUP alerts when PSU failure.
Example:
(SHELF_FAULT) ERROR
(CHASSIS POWER DEGRADED:Power Supply Status Critical:PSU1) ERROR
Scan to view the article on your device
