We are redesigning the NetApp Knowledge Base site to make it easier to use and navigate. The new and improved site will be available the first week of October. Check out our video or read this KB article to know more about changes you’ll see on the site.
What is a NFS op with the ONTAP operating system?
403
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
  • ONTAP 9
  • Data ONTAP 8
  • Data ONTAP 7-Mode
  • NFS version 3
Answer
  • A single Network File System operation (NFS op) is the combination of a NFS request from a client, and a NFS reply to the request from a server.
  • In many cases, a single NFS call will generate several NFS operations.
Example:
If an NFS client were to lookup a directory named /home/netapp , two NFS ops may be generated to determine if the /home/netapp directory already exists:
  1. NFS client performs a lookup of /home ; then the NFS server responds with the results.
  2. NFS client performs a lookup of /home/netapp ; then the NFS server responds with the results.
  • The list of NFS ops available to the client, and the number of calls per op can be viewed with the following command:
MyMac:~ nfsstat
Getattr      Setattr       Lookup     Readlink         Read        Write
   515            10            62         0            110         107
Create       Remove       Rename         Link      Symlink        Mkdir
   20            9            0            0            0            4
Rmdir      Readdir     RdirPlus       Access        Mknod       Fsstat
   0          55            24            17            0            77
Fsinfo     PathConf       Commit
   88            5            24
  •  Refer to your own nfsstat manual page for additional information.
Additional Information
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
