NetApp Knowledge Base
What baud rate do NetApp Controller console connections support
4,837
Visibility:
Votes:
3
Category:
not set
Specialty:
hw
Last Updated:
Applies to
  • FAS systems
  • AFF systems
  • Console Port
    • Micro-USB Serial
    • RJ45 Serial
Answer
  • All new NetApp controllers are designed to run at 115,200. The change was first made on the FAS8200 and AFF A300 platforms in BIOS release 10.0
  • The FAS22xx, FAS25xx, FAS32xx, FAS62xx and the FAS80xx run at 9600 baud
  • The speed is hard coded into the BIOS
Scan to view the article on your device
