What are Unified Target Adapter (UTA2)/CNA Ports and how to configure them?
Applies to
FAS SystemsAnswer
Unified Target Adapter (UTA2) ports are based on dual port ASIC design and are available on certain NetApp controllers and on specified add-on adapter cards and modules.
There are two ports on each ASIC that make up the port pairs of a given UTA2 device and are described below, based upon the platform:
FAS255x
FAS2650 / AFF A200
FAS27xx / AFF A220
e0c/e0d and e0e/e0f
FAS8020
e0c/0c and e0d/0d
FAS8040, FAS8060, & FAS8080
e0e/0e and e0f/0f
e0g/0g and e0h/0h
FAS8200 / AFF A300
e0e/0e and e0f/0f
e0g/0g and e0h/0h
FAS9000 / AFF A700
e1a/1a and e1b/1b
e1c/1c and e1d/1d
(This is for a Quad-port X91143A module installed in Slot 1.
For modules installed in other slots, the ports will be eXa/eXb and eXc/eXd accordingly for each respective slot.)
X1143A-R6 2-Port UTA2,10GbE,16Gb FC BareCage SFP+ add on adapter card.
Port 0/Port1
UTA2 ports can be configured as 16Gb FC or 10GbE (CNA)
- Both ports on a given ASIC must be set to same configuration.
- Changing one UTA2 port configuration will change the second port of the pair to the same configuration automatically.
When ordering any of the UTA2 equipped systems, it will be required to specify the configuration for the UTA2 ports. This will then allow the correct SFP+ for each respective port to be added to the order accordingly.
If the 10GbE configuration is selected and copper connections are required, the correct Cisco Twinax copper cables will need to be explicitly ordered for the respective ports. For cable part numbers, see the NetApp Hardware Universe for the respective system.
For the listed systems, manufacturing will set all UTA2 ports to the configuration based on the order as submitted and install the correct SFP+'s into the ports accordingly for non-copper configurations.
When ordering the X1143A-R6 option, the correct SFP+'s will need to be explicitly added to the order based upon the required configuration (FC or 10GbE). The ports are left in the default FC target configuration when the card is manufactured and will need to be manually configured at installation time.
FC Configuration Specific Details
- UTA2 ports will autorange between 4/8/16Gb FC speeds depending upon the back end connected switch configuration.
- Ports can be set to either an initiator or a target and can be set for each port explicitly in each port pair; i.e. one port can be an initiator and the other a target.
10GbE Configuration Specific Details
- UTA2 ports will not autorange below 10GbE speed.
- Supported protocols are FCoE, iSCSI, NFS, and CIFS.
- Ports can only be targets with FCoE and iSCSI.
1GbE is supported on the UTA2 ports as of Data ONTAP 8.2.4 and later as specified in KB: How to upgrade the flash image to support GbE connectivity to FAS2552 and FAS2554 systems with CNA or UTA2 ports, for both the 25XX and 8000 platforms.
For the FAS2650 / AFF A200 and FAS8200 / AFF A300 platforms, the 1GbE speed only requires the correct SFP to be installed in the respective ports.
1GbE is not supported for any of the UTA ports on FAS9000 / AFF A700.
For supported SFP/SFP+ for each respective platform, see KB How to determine the NetApp part number for Brocade and NetApp SFPs.
Configuring the UTA2 Ports
To reconfigure a port pair, the ports need to be taken offline first:
cluster_shell::> network fcp adapter modify -node <NODE_NAME> -adapter <UTA2_Port> -status-admin down
Then their configuration set to the required mode:
cluster_shell::> system node hardware unified-connect modify -node <NODE_NAME> -adapter <UTA2_Port> -mode <MODE> -type <TYPE>
The respective system will then need to be rebooted in order for the port configurations to become effective and the ports brought back on line with:
cluster_shell::> network fcp adapter modify -node <NODE_NAME> -adapter <UTA2_Port> -status-admin up
Notes
- <UTA2_PORT> should be specified as 0c, 0d, etc.
- <MODE> should be either fc (FC 4/8/16Gb) or cna (10GbE)
- <TYPE> is only required for FC configuration and will be initiator, target, or fcvi as required
To check the UTA ports configuration:
cluster_shell::> ucadmin show
This will show an output similar to:
Current Current Pending Pending Admin
Node Adapter Mode Type Mode Type Status
siteA-01 0e cna target - - online
siteA-01 0f cna target - - online
siteA-01 0g cna target - - online
siteA-01 0h cna target - - online
siteA-01 1a fc fcvi - - online
siteA-01 1b fc fcvi - - online
siteA-01 3a fc initiator - - online
siteA-01 3b fc initiator - - online
The system's current UTA2 port configurations can also be seen in a weekly AutoSupport in the UNIFIED-CONNECT.XML section.
Additional Information
N/A
